Part Number: LMP7708
Dear,
I purchased below part through MOUSER on 1/26 and I found a failure issue.
Dear,
It does sound like you use LMP7708 in a buffer configuration but as Kai said in order to be stable this op amp requires higher close-loop gain.
In order to stabilized decompensated op amps, you must increase the close-loop gain, Gmin, so it crosses AOL at f2 or lower frequency. In case of LMP7708 recommended min gain is 10 or higher - see below.
