Other Parts Discussed in Thread: TLV8812
Hello:
Please help recommend suitable TI chip which is close to TSU111ICT in function. Thanks!!!
Hello:
Hi Jimmy,
I checked with op amp cross reference tools and did not find the direct recommendation. However, the TLV8811 or TLV8812 looks like a good replacement, and it is currently in stock.
Enclosed are additional recommendation that may work for your application. For instance, LPV821 is a nanopower, zero-drift amplifier, and it will perform much better among the recommended ICs below, especially in gas detectors, fault monitoring, strain gauges. temperature and other sensing applications, where drift may be a concern over a wide temperature range.
LPV821 part is also in stock currently.
If you have additional questions, please let us know.
Raymond
