Other Parts Discussed in Thread: OPA277, OPA132, OPA140, OPA656, OPA727
1. Attached is a simulation of a simple lead compensator built around the TI OPA277. It is exhibiting spectral peaking ~500kHz in the pass band. Actual measurements reveal this artifact occurs ~212 kHz. I have been unable to explain this phenomenon (originally I thought it was parasitic capacitance de-stabilizing the response) but the fact that the resonant behavior is present on the simulation leads me to believe it is related to the open loop response of the 277. Equally important, what means can be used to correct the resonant peak?
2. Are you familiar with the term “semi-differential” as relates to signal propagation? How is it different from true differential propagation? How is it typically implemented? How does it’s common mode rejection differ from true differential mode?
