TLV1704-SEP: Output Leakage
Part Number: TLV1704-SEP
We only specify the nominal leakage at room temperature (70nA) in the Nov2018 revision of the datasheet.
Do we have any guidance on the maximum leakage current that would be expected over process and the full temperature range?
  • Hello Steve,
    Our guidance would be 1uA, or 10uA if you wish to add some hefty margin
    For reasons I cannot go into here, it is not just a simple junction leakage and there is some interaction between the supply voltage and the output pull-up voltage.
