Part Number: INA293EVM
Other Parts Discussed in Thread: INA293
Hi all,
I'm trying to use the INA293EVM for measuring current in an electrochemistry application. I'm providing a differential voltage to Vs and GND using a 9V battery. I'm using a potentiometer at Vin+, and Vin- is connected to ground. When I measure Vout on a scope, I can't seem to get any measurement unless I connect the ground of my current supply (at Vin-) and the ground of the load, my battery (at GND). There is a note addressing this on page 7 of the datasheet, stating that the chip needs a common mode voltage at the inputs if the voltage supply is floating. However, since my battery is a totally floating power supply, there is no common mode voltage at the inputs. Does anyone know how to perform this measurement in a setup with a totally floating power supply without connecting the test and load grounds together? Thank you for your help.
EDIT: I created a block diagram of my new setup based on the responses to this question. Does this look like a viable setup for measuring current? Any suggestions/edits are appreciated.
