Hi team,
While PCBA, customer needs to do ICT test to ensure the good welding of IC. They usually add negative votlage on IC pin and GND and test the voltage drop of internal ESD or clamp diode. If there is voltage drop, the welding is good. So customer need ICT test requirement for TLV2772QPWR including the negative voltage range added on each pin and the current limit they should set.
Thanks and best regards
