Other Parts Discussed in Thread: CSD18514Q5A, SN7693003, LM317
Hello Respected,
Please provide us the Applied/placement force & ESD data below provided MPN.
| Item number | Description | Manufacturer | MPN | Applied/Placement Force |
| 891-DYGZ-255248-01/02 | IC (POWER)-LDO Regulator 3.3V 150mA Texas Instruments TPS70933DRV | TEXAS INSTRUMENTS | TPS70933DRVR | |
| 891-DYGZ-320860-01/02 | IC (POWER)-Voltage Regulator 1.25 to 37V 500mA TEXAS INSTRUMENTS LM317MDCY | TEXAS INSTRUMENTS | LM317MDCYR | |
| 891-DYGZ-240474-01/02 | IC (LINEAR)-Comparator Dual 5.5V Texas Instruments LMV393IPW | TEXAS INSTRUMENTS | LMV393IPWR | |
| 891-DYGZ-240299-01/02 | IC (POWER)-Battery Monitor 6 to 10 cell Texas Instruments SN7693003DBTR | TEXAS INSTRUMENTS | SN7693003DBTR | |
| 891-DYGZ-240299-01/02 | IC (POWER)-Battery Monitor 6 to 10 cell Texas Instruments SN7693003DBTR | TEXAS INSTRUMENTS | BQ7693003DBT | |
| 891-DYGZ-309571-01/02 | IC (LINEAR)-Comparator Single 7V Texas Instruments TLV3201AIDCK | TEXAS INSTRUMENTS | TLV3201AIDCKR | |
| 891-DYGZ-237494-01/01 | IC-Low side gate driver, 4A peak, SOT-23(5) TI UCC27517DBV | TEXAS INSTRUMENTS | UCC27517DBVR | |
| 891-DYGZ-237494-01/01 | IC-Low side gate driver, 4A peak, SOT-23(5) TI UCC27517DBV | TEXAS INSTRUMENTS | UCC27517DBV | |
| 891-DYGZ-237198-01/02 | TRANSISTOR (MOSFET)-MOSFET N-Channel 40V 18A 3.1W SON TI CSD18514Q5A | TEXAS INSTRUMENTS | CSD18514Q5A | |
| 891-DYGZ-236798-01/02 | IC-Op-amp single SC70 10MHz 12V TI LMV641MGx/NOPB | TEXAS INSTRUMENTS | LMV641MGX/NOPB |
| Item number | Description | Manufacturer | MPN | ESD Data - HBM | ESD Data - MM | ESD Data - CDM |
| 891-DYGZ-320860-01/02 | IC (POWER)-Voltage Regulator 1.25 to 37V 500mA TEXAS INSTRUMENTS LM317MDCY | TEXAS INSTRUMENTS | LM317MDCYR | |||
| 891-DYGZ-240299-01/02 | IC (POWER)-Battery Monitor 6 to 10 cell Texas Instruments SN7693003DBTR | TEXAS INSTRUMENTS | SN7693003DBTR | |||
- Note 1: Placement /Applied Force: - Placement force/applied force is the Force required to place the Component on PCB.
- Note 2: ESDS is Electrostatic Discharge Sensitivity, The ESD level that causes component failure.
# 人体带电模型 ( Human Body Model , HBM )
# 机器带电模型( Machine Model , MM )
# 组件带电模型( Charged Device Model , CDM )
Umesh Prasad
