Other Parts Discussed in Thread: INA301, INA302
Hello Jonathan,
Thanks for the question. There are a couple of avenues to consider here. For filtering on input some gain loss and input offset error will be introduced. It will be important to keep filter resistor values low and aim for short and even traces to limit uneven stray capacitance. I would note that the typical application schematic referenced in data sheet has 100n capacitor tied to ground on alert pull up; cap on input should also likely fall in this realm.
You could also look at powering up device after startup, bringing up supply pin only after load settles. Coding a blank on comparator input from alert pin for length of load settling time might also be an option.
7.4 of data sheet looks at input filtering consideration with later part discussing means of dealing with transients beyond common mode range:
INA301 36-V, High-Speed, Zero-Drift, Voltage-Output, Current-Shunt Monitor with High-Speed, Overcurrent Comparator datasheet (Rev. A) (ti.com)
