Part Number: LM7321-Q1
Other Parts Discussed in Thread: LM7321
the common mode voltage Vcm can reach supply voltage in customer application (or also overshot). Therefor customer need following parameter:
- Vcm max rating (needed so that the IC will not be damaged) which is included in the d/s:
- recommended input voltage range (needed so that IC will function correct). This parameter is not included in the d/s. Can you give a recommendation?
Regards Holger
