Part Number: OPA547
Other Parts Discussed in Thread: OPA551,
I designed a zero resistance ammeter using OPA 551. Supply is +/- 15 V. The output offset was within 1 mV, esily trimmed off by feeding a small voltage to the non-inv input.
Now I replaced the OPA 551 with OPA 547 to get more current capability.
I expected an offset of somewhat below 2 mV. Indeed, on 20 identical boards, we found an offset of approx. - 7 mV (same on all boards) at the output, when pin 1 es set to GND. We had to feed 7 mV to pin 1 in order to trim off the output offset.
Is that the expected behaviour?
Best regards
Rudolf Doelling
