Part Number: AMC3330EVM
Other Parts Discussed in Thread: AMC3330
Are the design files or Gerbers available for the AMC3330EVM?
Hi Daniel,
Can you share some additional information about your application and why you would like to have the design/Gerber files of the EVM?
Our EVM is not to be used in commercial applications as it has not been rated for high voltage operation.
Hi Alexander,
The EVM design files would be used as a starting point, but would certainly be modified. It's a research application, not commercial. I'm intending to build some prototypes using the AMC3330 to see how well it will work. I need to determine current by measuring voltage across a large (10kohm-ish) shunt resistor, where that shunt resistor will experience kV level transients regularly.
Altium Designer files would be ideal.
Hi Daniel,
May I contact you offline using the email address your TI account is registered with?
