Part Number: THS4541
What is the minimum input voltage level of THS4541 Op amp?
Hello Eswar,
Are you referring to the input voltage range of the device? This will depend on the power supply configuration. The below snippet is from the THS4541 datasheet:
The specification refers to the voltage directly at the input of the amplifier. A higher voltage can be present at the RG resistors; models/simulations found in product folder's Design & Development tab can be used to determine your input range as well as Kai's noise suggestion.
Thank you,
Sima
