Part Number: LM358
Hi, Support Team
Please review as below schematic, have any concern?
Note: TA:45 deg
if any, Please advise me.
Lawrence
Part Number: LM358
Hi, Support Team
Note: TA:45 deg
Lawrence
Hi Lawrence,
shall this be a comparator circuit? In this case you may profit from adding hysteresis since the thermistor may cause a very slowly changing signal and the output may otherwise oscillate.
And if the thermistor is mounted remotely from the OPAmp, adding an input low pass filter can help to suppress EMI.
What is R8280 and what is the resistance of thermistor? I ask because the LM358 shows a rather high input bias current which may cause a relevant offset voltage across the source resistance resulting in some measuring error.
Kai
Lawrence,
What is the output load?
