Other Parts Discussed in Thread: PGA281, PGA280, PGA204, PGA205
Any suggestions of what part I can replace PGA280AIPWR with. I can't get the part but the time need is sooner than when it will be available
Jacques, We do not have a pin-for-pin device to the PGA280, but if you are still in the design stage you can use the PGA281. The PGA281 is the same core, but does not have an SPI interface. It uses GPIO to set the gain. There are other PGA options but the 280 is closest from a functional perspective.
Art
Jacques,
The PGA204, and PGA205 are in stock. This isn't really an equivalent as the output is single ended and doesn't have the clamp capability, but depending on your use case this may work. I will send you a friend request to send you a private message. We may have a new device that will be available soon that you may be interested in.
Art
