Part Number: OPA2365
Other Parts Discussed in Thread: TIPD127,
Dear members,
We supposed to use a high precision voltage sensor in one of our products but we couldn't find what we really need to buy and then we decided to make a one ourselves. We used two TI tutorials:
1- Analog Pulse Width Modulation for making the PWM in fuction of input voltage "www.ti.com/lit/ug/slau508/slau508.pdf?ts=1682608456773"
2- Micro controller PWM to 12 bits Analog out as the DAC. "www.ti.com/.../TIPD127
I have a bunch of questions about it and I will appreciate deeply if anybody can help me,
Requirements:
I need to make a sensor to sense 0 to 6KV DC voltage. The Switching frequency is 500KHz.
You can find the SCH of what I have done so far:
for the DAC part I used the TINA simulation and I changed the values to what I supposed they could be working for us.
I haven't put the fiber optic dirver and powersupply parts yet. But the idea is to generate the PWM and then connect it to DAC via a fiber optic.
Doubts
1- I used the resistors to reduce the voltage. But as it obvious the power dissipation will be too much on each one. is it necessary to use the opto-amplifier?
2- The tutorials were done to make a PWM of a biopolar signal while mine is a DC one so no need to have an OFFSET but I'm not sure if it's going to work as we expect.
any suggestion would be deeply welcomed.
Farzaneh
