Part Number: OPA2670
Other Parts Discussed in Thread: TINA-TI, OPA2675, OPA695
I have used OPA2670 for our new design. So please Could you give me TINA-TI model of OPA2670 asap?
Niranjan
Hi Niranjan,
Can you check OPA2675 specification also once, it's a newer device and if it meets your requirement, I would suggest to use this instead of OP2670.
TINA model for OPA2675 is also available in TI.com.
Anant
Hi Anant,
I have to check the OPA2675 specification, it's a dual Input and output amplifier and we have required a single I/P and O/P channel.
So Can you suggest any other amplifier instead of OP2670,Which has less flatness in the entire 50 MHz BW. and capable of 10 Vpp Output.
Niranjan
Hi Niranjan,
Both OPA2670 and OPA2675 are dual channel current feedback amplifier targetting similar application having same package and pinout.
For your application do you need a current feedback amplifier or a voltage feedback amplifier. What's the slew rate you need?
Anant
Hi Anant,
We want to used Current feedback amplifier and slew rate should be high i.e grater than 2500 V /usec. So please suggest accordingly.
Niranjan
Hi Niranjan,
Please check OPA695, it's 12V current-feedback opamp having slew rate of 4300V/us.
https://www.ti.com/product/OPA695
Anant
Hi Anant,
Niranjan,
I am closing this thread here, for differential filter design, we will look for the part to fit your requirement and communicate it to you in the other thread you created.
Anant
