Part Number: LMH6882
In which order I should load registers to the device (SPI mode).
Thanks.
Hello Ivan,
Could you clarify what you are asking? I can interpret your question in two ways:
- Which registers need to be set prior to other registers? Does the order I change control bits for registers impact performance?
- Which bits are Most Significant Bits or Least Significant Bits? How do I determine the correct binary values to load into the address bit to select a register?
I am also attaching two older threads that may help. Please let me know more about what you are asking.
Alec
