Part Number: OPA2541
We have received this product for product testing. One product failed to pass the normal temperature test and the other was short circuit. Could you please confirm what caused it
thank you
Hi Emily,
Could you describe a bit about the issues? Could you send me the testing circuit and short circuit tests including the supply rails? The attached file is not supported by E2E and I am unable to read it. The text image is a bit blur as well. Please send me the higher resolution image or pdf files.
Please describe the tests, Are these ATE tests to verify the functionality of the part. I assumed that these parts are purchased from TI E-store or TI Authorized distributors.
You may describe the failure in Chinese. How many are failed due to the tests or failure rate etc.?
Raymond
Hi Emily,
The attachment you enclosed is not supported by E2E forum, thus I am unable to access it. What is the file that you tried to send to us? If the attachment is a video clip, you need to change the video clip format. Otherwise, we are unable to view it or play it over the E2E forum.
有一只常温测试不合格,以上报告是测试截图,还有一只是壳和脚短路
It seems that these are quality issues. Please contact the customer support center and arrange for a return.
https://education.ti.com/en/customer-support/support-worldwide
The application team is supporting technical related issues about our product. If you have the specification, design or op amp instability issues etc., I will be happy to work with you.
If you have other questions, please let me know.
Raymond
Hi Emily,
To be frank, I do not know either. I have to go ask the E2E administrator (they are all gone home currently). However, please see if the Quicktime video format will work (My guess). You should be able to preview the contents by clicking on Tools at the bottom of the tool bar.
The image below is what I see when I try to click on it - where the plugin is not supported.
Raymond
Hi Emily,
I asked the E2E support engineer, he implies that MP4 video format may be the compatible format. I never submitted anything in video format, and I do not know how to properly upload video format onto the E2E. It should be similar to upload a file.
I will be OOO, so it may be quicker for you to contact our customer service in China. Generally, the application team does not support the quality related issues in our product, since there is another team to handle the customer's complains and/or issues.
Raymond
Hi Emily
The E2E engineer downloaded the video for me, and I see the few second video clip when a pin is shorted to a case.
I have to say that I agree with you. One of the feature per the OPA2541BM TO-3 package is stated that the TO-3 package or case is isolated from all internal circuitry. I think that you should proceed to return the failed items to TI E-store.
Sorry for the delay. The E2E is doing the unexpected maintences in the past two days. We are all locked out.
Raymond
