OPA2376: I need spice model to execute in the LTspice software.
Part Number: OPA2376
Hi Team,
Greetings!
Kindly share us the LTspice model this OPA2376AIDR.
Regards!
Poornima D
  • Poornima,
    Unfortunately due to the licensing agreement on LT SPICE, ADI is the only semiconductor manufacture that can provide models or use LT SPICE.  We cannot provide tested LT SPICE models.  You can take the PSPICE netlist and import it into LT SPICE.  In some cases this works well, but not always.  We cannot trouble shoot any issues.  Sorry about this, I wish we could provide more support in this regard.
    Art
  • Thanks for the response.
    Kindly share the Pspice netlist, let's try if it could work that would be fine. else needs to analytical analysis.
  • Poornima,
    Below if the PSPICE "LIBARY" file.  I renamed it as a text file.  This file contains the net list of the spice model.  In the future, you can download the PSPICE model zip file from TI.com under "design tools and simulation".  The key file will have the extension *.LIB.  You can open this file with at text editor.
    OPAx376.txt
    * OPAx376
    * (C) Copyright 2022 Texas Instruments Incorporated. All rights reserved.
    ** This model is designed as an aid for customers of Texas Instruments.
    ** TI and its licensors and suppliers make no warranties, either expressed
    ** or implied, with respect to this model, including the warranties of
    ** merchantability or fitness for a particular purpose.  The model is
    ** provided solely on an "as is" basis.  The entire risk as to its quality
    ** and performance is with the customer
    * This model is subject to change without notice. Texas Instruments
    * Incorporated is not responsible for updating this model.
    ** Released by: Online Design Tools, Texas Instruments Inc.
    * Part: OPAx376
    * Date: 2JUN2022
    * Model Type: Generic (suitable for all analysis types)
    * EVM Order Number: N/A
    * EVM Users Guide:  N/A
    * Datasheet: SBOS406G -JUNE 2007-REVISED DECEMBER 2015
    * Created with Green-Williams-Lis Op Amp Macro-model Architecture
    * Model Version: Final 1.4
    * Updates:
    * Final 1.4
    * 1. Modified the capacitor(C14) value from 1F to 1uF in GND Float-IQ block
    *    to resolve the convergence issue in single and asymmetric supply test.
    * 2. Resolved bump in Aol curve at lower frequency by shifting Zo First pole
    *    nearer to Aol First pole.
    * Final 1.3
    * In CMRR block, R81 resistor is changed from 1.92e3 to 1.92e6 to fix the dc
    * gain of CMRR
    * Final 1.2
    * VOS drift feature is added
    * Added Unique subckt name, removed Claw ABS.
    * Simplified subckt for current noise.
    * Final 1.1
    * Release to Web.
    * Model Usage Notes:
    * 1. The following parameters are modeled:
    *    a. OPEN-LOOP GAIN AND PHASE VS. FREQUENCY  WITH RL, CL EFFECTS (Aol)
    *    b. UNITY GAIN BANDWIDTH (GBW)
    *    c. INPUT COMMON-MODE REJECTION RATIO VS. FREQUENCY (CMRR)
    *    d. POWER SUPPLY REJECTION RATIO VS. FREQUENCY (PSRR)
    *    e. DIFFERENTIAL INPUT IMPEDANCE (Zid)
    *    f. COMMON-MODE INPUT IMPEDANCE (Zic)
    *    g. OPEN-LOOP OUTPUT IMPEDANCE VS. FREQUENCY (Zo)
    *    h. OUTPUT CURRENT THROUGH THE SUPPLY (Iout)
    *    i. INPUT VOLTAGE NOISE DENSITY VS. FREQUENCY (en)
    *    j. INPUT CURRENT NOISE DENSITY VS. FREQUENCY (in)
    *    k. OUTPUT VOLTAGE SWING vs. OUTPUT CURRENT (Vo)
    *    l. SHORT-CIRCUIT OUTPUT CURRENT (Isc)
    *    m. QUIESCENT CURRENT (Iq)
    *    n. SETTLING TIME VS. CAPACITIVE LOAD (ts)
    *    o. SLEW RATE (SR)
    *    p. SMALL SIGNAL OVERSHOOT VS. CAPACITIVE LOAD
    *    q. LARGE SIGNAL RESPONSE
    *    r. OVERLOAD RECOVERY TIME (tor)
    *    s. INPUT BIAS CURRENT (Ib)
    *    t. INPUT OFFSET CURRENT (Ios)
    *    u. INPUT OFFSET VOLTAGE (Vos)
    *    v. INPUT OFFSET VOLTAGE VS. TEMPERATURE (Vos Drift)
    *    w. INPUT COMMON-MODE VOLTAGE RANGE (Vcm)
    *    x. INPUT OFFSET VOLTAGE VS. INPUT COMMON-MODE VOLTAGE (Vos vs. Vcm)
    *    y. INPUT/OUTPUT ESD CELLS (ESDin, ESDout)
    * 2. OPAx376 model is available in single core(OPA376), dual core(OPA2376)
    *    and quad core(OPA4376)
    .SUBCKT OPAx376 IN+ IN- VCC VEE OUT
    C_C1          N5296613 N5296623  60.3F
    C_C10         N5298247 N5298259  11U
    C_C123        N5296633 N5296643  62.4P
    C_C13         N5302951 0  1F
    C_C14         0 N5302475  1U
    C_C146        N5719031 N5665974  344F
    C_C147        N5298821 MID  10.4F
    C_C148        N57803740 MID  26.5P
    C_C15         N5302991 0  1F
    C_C152        N5896474 N5896484  60.3F
    C_C153        N5905339 N5905349  344F
    C_C154        N5785671 N5299107  265F
    C_C16         N5301567 MID  1F
    C_C17         N5302227 MID  1F
    C_C18         N5301581 MID  1F
    C_C19         N5302261 MID  1F
    C_C20         N5301595 MID  1F
    C_C21         N5302295 MID  1F
    C_C22         MID N5301537  1F
    C_C23         N5303823 MID  1F
    C_C24         N5304615 MID  1F
    C_C25         N5304181 MID  1P
    C_C26         N5304435 MID  1P
    C_C27         SW_OL_OPAx376 MID  1P
    C_C29         VIMON MID  1N
    C_C30         VOUT_S MID  1N
    C_C4          N5299343 MID  1F
    C_C5          CLAMP MID  140N
    C_C70         VCLP MID  100P
    C_C_COM0      ESDP MID  13P
    C_C_COM1      MID ESDN  13P
    C_C_DIFF      ESDN ESDP  6.5P
    E_E1          MID 0 N5302475 0 1
    E_E3          N5297811 MID OUT MID 1
    E_E4          N5297995 MID CL_CLAMP MID 1
    G_G1          N5296613 MID ESDP MID -1.68M
    G_G104        N5298821 MID VSENSE MID -1U
    G_G107        CLAW_CLAMP MID N5298821 MID -1M
    G_G108        CL_CLAMP MID CLAW_CLAMP MID -1M
    G_G111        N5665974 MID VCC_B MID -342U
    G_G112        N5781207 MID N5298259 MID -661.54
    G_G113        N5785671 MID N5783853 MID -1
    G_G116        N5896474 MID N5296623 MID -1
    G_G117        N5859234 MID N5896484 MID -53.03
    G_G118        N5905349 MID N5719031 MID -1
    G_G119        N5296765 MID N5905339 MID -71.43
    G_G18         VCC_B 0 VCC 0 -1
    G_G19         VEE_B 0 VEE 0 -1
    G_G2          N5297947 N5297941 N5859234 MID -1M
    G_G20         VCC_CLP MID N5303823 MID -1M
    G_G21         VEE_CLP MID N5304615 MID -1M
    G_G22         N5304315 MID N5304303 MID -1
    G_G23         N5304383 MID N5304405 MID -1
    G_G39         N5298247 MID CL_CLAMP N5298565 -89.3
    G_G5          N5297697 N5297689 N5296765 N5296643 -1M
    G_G6          VSENSE MID CLAMP MID -1M
    G_G96         N5296633 MID VEE_B MID -46.92M
    I_I_B         N5298577 MID DC 200F
    I_I_OS        ESDN MID DC 1F
    I_I_Q         VCC VEE DC 760U
    R_R15         N5297689 N5297947 R_NOISELESS 1M
    R_R16         N5297697 N5297689 R_NOISELESS 1K
    R_R167        N5297995 VCLP R_NOISELESS 100
    R_R17         N5300247 ESDN R_NOISELESS 1M
    R_R18         MID N5298335 R_NOISELESS 1T
    R_R19         MID N5300937 R_NOISELESS 1T
    R_R20         N5299325 MID R_NOISELESS 1
    R_R21         N5299343 N5299325 R_NOISELESS 1M
    R_R22         MID N5298735 R_NOISELESS 1MEG
    R_R23         MID CLAMP R_NOISELESS 1MEG
    R_R24         MID VSENSE R_NOISELESS 1K
    R_R266        MID N5298821 R_NOISELESS 1MEG
    R_R297        N5296643 N5296633 R_NOISELESS 100MEG
    R_R300        MID N5296643 R_NOISELESS 10.2K
    R_R301        MID N5296633 R_NOISELESS 1
    R_R334        MID CLAW_CLAMP R_NOISELESS 1K
    R_R335        MID CL_CLAMP R_NOISELESS 1K
    R_R34         N5298259 N5298247 R_NOISELESS 10K
    R_R35         MID N5298247 R_NOISELESS 1
    R_R358        MID N5665974 R_NOISELESS 1
    R_R359        N5665974 N5719031 R_NOISELESS 100MEG
    R_R36         MID N5298259 R_NOISELESS 15.14
    R_R360        MID N5719031 R_NOISELESS 1.42MEG
    R_R361        MID N5781207 R_NOISELESS 1
    R_R362        N5783853 N5781207 R_NOISELESS 990K
    R_R363        N5783853 N57803740 R_NOISELESS 10K
    R_R373        N5896484 N5896474 R_NOISELESS 100MEG
    R_R374        MID N5896474 R_NOISELESS 1
    R_R375        MID N5896484 R_NOISELESS 1.92MEG
    R_R376        MID N5859234 R_NOISELESS 1
    R_R377        N5905349 N5905339 R_NOISELESS 100MEG
    R_R378        MID N5905339 R_NOISELESS 1.42MEG
    R_R379        MID N5905349 R_NOISELESS 1
    R_R380        MID N5296765 R_NOISELESS 1
    R_R381        N5299107 N5785671 R_NOISELESS 10K
    R_R382        MID N5785671 R_NOISELESS 1
    R_R383        MID N5299107 R_NOISELESS 6
    R_R43         MID N5299111 R_NOISELESS 1
    R_R46         VCC_B 0 R_NOISELESS 1
    R_R47         VCC_B N5302951 R_NOISELESS 1M
    R_R48         N5302951 N5302475 R_NOISELESS 1MEG
    R_R49         N5302475 0 R_NOISELESS 1T
    R_R5          MID N5296613 R_NOISELESS 1
    R_R50         N5302475 N5302991 R_NOISELESS 1MEG
    R_R51         N5302991 VEE_B R_NOISELESS 1M
    R_R52         VEE_B 0 R_NOISELESS 1
    R_R53         VCC_CLP MID R_NOISELESS 1T
    R_R54         N5301563 MID R_NOISELESS 1
    R_R55         N5301567 N5301563 R_NOISELESS 1M
    R_R56         VEE_CLP MID R_NOISELESS 1T
    R_R57         N5302333 MID R_NOISELESS 1
    R_R58         N5302227 N5302333 R_NOISELESS 1M
    R_R59         N5301533 MID R_NOISELESS 1T
    R_R6          N5296623 N5296613 R_NOISELESS 100MEG
    R_R60         N5301577 MID R_NOISELESS 1
    R_R61         N5301581 N5301577 R_NOISELESS 1M
    R_R62         N5302261 N5302369 R_NOISELESS 1M
    R_R63         N5302495 MID R_NOISELESS 1T
    R_R64         N5302369 MID R_NOISELESS 1
    R_R65         N5301543 MID R_NOISELESS 1T
    R_R66         N5301591 MID R_NOISELESS 1
    R_R67         N5301595 N5301591 R_NOISELESS 1M
    R_R68         N5302295 N5302405 R_NOISELESS 1M
    R_R69         N5302499 MID R_NOISELESS 1T
    R_R7          MID N5296623 R_NOISELESS 1.92MEG
    R_R70         N5302405 MID R_NOISELESS 1
    R_R71         N5301537 VSENSE R_NOISELESS 1M
    R_R72         VCC_B N5303741 R_NOISELESS 1K
    R_R73         N5303741 N5303823 R_NOISELESS 1M
    R_R74         N5304593 VEE_B R_NOISELESS 1K
    R_R75         N5304593 N5304615 R_NOISELESS 1M
    R_R76         MID VCC_CLP R_NOISELESS 1K
    R_R77         VEE_CLP MID R_NOISELESS 1K
    R_R78         N5304383 MID R_NOISELESS 1
    R_R79         N5304315 MID R_NOISELESS 1
    R_R8          N5297947 N5297941 R_NOISELESS 1K
    R_R80         V11 N5304181 R_NOISELESS 100
    R_R81         V12 N5304435 R_NOISELESS 100
    R_R82         N5304195 MID R_NOISELESS 1
    R_R83         N5304195 SW_OL_OPAx376 R_NOISELESS 100
    R_RDUMMY      MID N5298565 R_NOISELESS 10K
    R_RS_INN      IN- ESDN R_NOISELESS 10M
    R_RS_INP      IN+ ESDP R_NOISELESS 10M
    R_RX          N5298565 N5299111 R_NOISELESS 100K
    R_RX1         MID N5298043 R_NOISELESS 1T
    R_RX2         VIMON N5298043 R_NOISELESS 100
    R_RX3         MID N5297811 R_NOISELESS 1T
    R_RX4         VOUT_S N5297811 R_NOISELESS 100
    R_R_CM1       ESDP MID R_NOISELESS 1T
    R_R_CM2       MID ESDN R_NOISELESS 1T
    V_VCM_MAX     N5298335 VCC_B 100M
    V_VCM_MIN     N5300937 VEE_B -100M
    V_V_GRN       N5302499 MID -60
    V_V_GRP       N5301543 MID 40
    V_V_ISCN      N5302495 MID -51
    V_V_ISCP      N5301533 MID 33
    V_V_ORN       N5304303 VCLP -630M
    V_V_ORP       N5304405 VCLP 630M
    X_H1          N5298565 OUT N5298043 MID BLOCK_DC_H1_OPAx376
    X_H2          N5303803 N5304383 V12 MID BLOCK_DC_H2_OPAx376
    X_H3          N5303747 N5304315 V11 MID BLOCK_DC_H3_OPAx376
    X_S1          N5303747 CLAMP N5303747 CLAMP BLOCK_DC_S1_OPAx376
    X_S2          CLAMP N5303803 CLAMP N5303803 BLOCK_DC_S2_OPAx376
    X_U10         VCC_CLP VEE_CLP VOUT_S MID N5301563 N5302333 CLAMP_AMP_LO_OPAx376 PARAMS:
    +  G=1
    X_U11         N5301533 N5302495 VIMON MID N5301577 N5302369 CLAMP_AMP_LO_OPAx376
    +  PARAMS: G=1
    X_U12         N5301543 N5302499 N5301537 MID N5301591 N5302405 CLAMP_AMP_HI_OPAx376
    +  PARAMS: G=10
    X_U16         MID N5304195 N5304181 N5304435 OL_SENSE_OPAx376
    X_U18         VIMON MID N5303741 VCC_B CLAWP_OPAx376
    X_U19         MID VIMON VEE_B N5304593 CLAWN_OPAx376
    X_U21         OUT VCC VEE ESD_OUT_OPAx376
    X_U22         N5301581 N5302261 CL_CLAMP MID CL_SRC_OPAx376 PARAMS: GAIN=1 IPOS=240E-3
    +  INEG=-240E-3
    X_U23         N5301595 N5302295 CLAMP MID GR_SRC_OPAx376 PARAMS: GAIN=1 IPOS=0.6E1
    +  INEG=-0.6E1
    X_U25         SW_OL_OPAx376 MID N5298247 N5298259 SW_OL_OPAx376
    X_U26         VIMON MID VCC MID IQ_SRC_OPAx376 PARAMS: GAIN=1E-3
    X_U27         MID VIMON MID VEE IQ_SRC_OPAx376 PARAMS: GAIN=1E-3
    X_U30         N5299343 N5300247 MID N5298735 AOL_1_OPAx376 PARAMS: GAIN=1E-4 IPOS=.5
    +  INEG=-.5
    X_U31         N5298735 MID MID CLAMP AOL_2_OPAx376 PARAMS: GAIN=61.86E-3 IPOS=0.28
    +  INEG=-0.28
    X_U32         N5299107 MID MID N5299111 ZO_SRC_OPAx376 PARAMS: GAIN=1667 IPOS=6.4E3
    +  INEG=-10E3
    X_U35         N5301567 N5302227 CLAW_CLAMP MID CLAW_SRC_OPAx376 PARAMS: GAIN=1
    +  IPOS=80E-3 INEG=-120E-3
    X_U36         MID N5298577 FEMT_OPAx376 PARAMS: NVRF=2
    X_U38         N5297941 N5895272 VCC VEE VOS_SRC_OPAx376
    X_U4          N5895272 N5298577 VOS_DRIFT_OPAx376 PARAMS: DC=-21.32E-06 POL=1
    +  DRIFT=0.32E-06
    X_U41         ESDN MID FEMT_OPAx376 PARAMS: NVRF=2
    X_U43         ESDP N5298577 VNSE_OPAx376 PARAMS: FLW=1 GLF=0.0473 RNV=66.6
    X_U5          ESDN ESDP VCC VEE ESD_IN_OPAx376
    X_U6          N5297697 MID N5299325 MID N5298335 N5300937 VCM_CLAMP_OPAx376 PARAMS:
    +  GAIN=1
    .MODEL R_NOISELESS RES (T_ABS=-273.15)
    .ENDS OPAx376
    .SUBCKT BLOCK_DC_H1_OPAx376 1 2 3 4
    H_H1         3 4 VH_H1 1K
    VH_H1         1 2 0V
    .ENDS  BLOCK_DC_H1_OPAx376
    .SUBCKT BLOCK_DC_H2_OPAx376 1 2 3 4
    H_H2         3 4 VH_H2 1
    VH_H2         1 2 0V
    .ENDS  BLOCK_DC_H2_OPAx376
    .SUBCKT BLOCK_DC_H3_OPAx376 1 2 3 4
    H_H3         3 4 VH_H3 -1
    VH_H3         1 2 0V
    .ENDS  BLOCK_DC_H3_OPAx376
    .SUBCKT BLOCK_DC_S1_OPAx376 1 2 3 4
    S_S1         3 4 1 2 _S1
    RS_S1         1 2 1G
    .MODEL         _S1 VSWITCH ROFF=1E9 RON=10M VOFF=0.0V VON=10MV
    .ENDS  BLOCK_DC_S1_OPAx376
    .SUBCKT BLOCK_DC_S2_OPAx376 1 2 3 4
    S_S2         3 4 1 2 _S2
    RS_S2         1 2 1G
    .MODEL         _S2 VSWITCH ROFF=1E9 RON=10M VOFF=0.0V VON=10MV
    .ENDS  BLOCK_DC_S2_OPAx376
    .SUBCKT AOL_1_OPAx376 VC+ VC- IOUT+ IOUT- PARAMS: GAIN=1E-4 IPOS=.5 INEG=-.5
    G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)}
    .ENDS  AOL_1_OPAx376
    .SUBCKT AOL_2_OPAx376 VC+ VC- IOUT+ IOUT- PARAMS: GAIN=61.86E-3 IPOS=0.28 INEG=-0.28
    .ENDS  AOL_2_OPAx376
    .SUBCKT CLAMP_AMP_HI_OPAx376 VC+ VC- VIN COM VO+ VO- PARAMS: G=1
    GVO+ COM VO+ VALUE = {IF(V(VIN,COM)>V(VC+,COM),((V(VIN,COM)-V(VC+,COM))*G),0)}
    GVO- COM VO- VALUE = {IF(V(VIN,COM)<V(VC-,COM),((V(VC-,COM)-V(VIN,COM))*G),0)}
    .ENDS  CLAMP_AMP_HI_OPAx376
    .SUBCKT CLAMP_AMP_LO_OPAx376 VC+ VC- VIN COM VO+ VO- PARAMS: G=1
    .ENDS  CLAMP_AMP_LO_OPAx376
    .SUBCKT CLAWN_OPAx376 VC+ VC- IOUT+ IOUT-
    G1 IOUT+ IOUT- TABLE {(V(VC+,VC-))} =
    +(0,  1.056E-5)
    +(18.2, 2.9E-4)
    +(35,   5.9E-4)
    +(40,   7.4E-4)
    +(42.7, 8.2E-4)
    +(45,   9.5E-4)
    +(46,  1.03E-3)
    +(48.1,1.33E-3)
    +(51,  1.95E-3)
    .ENDS  CLAWN_OPAx376
    .SUBCKT CLAWP_OPAx376 VC+ VC- IOUT+ IOUT-
    +(0, 1.058E-5)
    +(10,    2E-4)
    +(15,  3.1E-4)
    +(20,  4.5E-4)
    +(22.5,5.5E-4)
    +(25,  6.7E-4)
    +(27.5,  9E-4)
    +(30,  1.3E-3)
    +(33, 1.88E-3)
    .ENDS  CLAWP_OPAx376
    .SUBCKT CLAW_SRC_OPAx376 VC+ VC- IOUT+ IOUT- PARAMS: GAIN=1 IPOS=80E-3 INEG=-120E-3
    .ENDS  CLAW_SRC_OPAx376
    .SUBCKT CL_SRC_OPAx376 VC+ VC- IOUT+ IOUT- PARAMS: GAIN=1 IPOS=240E-3 INEG=-240E-3
    .ENDS  CL_SRC_OPAx376
    .SUBCKT ESD_IN_OPAx376 ESDN ESDP VCC VEE
    .MODEL ESD_SW VSWITCH(RON=50 ROFF=1E12 VON=500E-3 VOFF=100E-3)
    S1 ESDN VCC ESDN VCC ESD_SW
    S2 ESDP VCC ESDP VCC ESD_SW
    S3 VEE ESDN VEE ESDN ESD_SW
    S4 VEE ESDP VEE ESDP ESD_SW
    .ENDS  ESD_IN_OPAx376
    .SUBCKT ESD_OUT_OPAx376 OUT VCC VEE
    S1 OUT VCC OUT VCC ESD_SW
    S2 VEE OUT VEE OUT ESD_SW
    .ENDS  ESD_OUT_OPAx376
    .SUBCKT FEMT_OPAx376 1 2 PARAMS: NVRF=2
    E1 3 0 5 0 10
    R1 5 0 {1.184*PWR(NVRF,2)}
    R2 5 0 {1.184*PWR(NVRF,2)}
    G1 1 2 3 0 1E-6
    .ENDS  FEMT_OPAx376
    .SUBCKT GR_SRC_OPAx376 VC+ VC- IOUT+ IOUT- PARAMS: GAIN=1 IPOS=0.6E1 INEG=-0.6E1
    .ENDS  GR_SRC_OPAx376
    .SUBCKT IQ_SRC_OPAx376 VC+ VC- IOUT+ IOUT- PARAMS: GAIN=1E-3
    G1 IOUT+ IOUT- VALUE={IF( (V(VC+,VC-)<=0),0,GAIN*V(VC+,VC-) )}
    .ENDS  IQ_SRC_OPAx376
    .SUBCKT OL_SENSE_OPAx376 COM SW+ OLN OLP
    GSW+ COM SW+ VALUE = {IF((V(OLN,COM)>5E-3 | V(OLP,COM)>5E-3),1,0)}
    .ENDS  OL_SENSE_OPAx376
    .SUBCKT SW_OL_OPAx376 SW_OL_OPAx376 MID CAP_L CAP_R
    .MODEL OL_SW VSWITCH(RON=1E-3 ROFF=1E9 VON=900E-3 VOFF=800E-3)
    S1 CAP_L CAP_R SW_OL_OPAx376 MID OL_SW
    .ENDS  SW_OL_OPAx376
    .SUBCKT VCM_CLAMP_OPAx376 VIN+ VIN- IOUT- IOUT+ VP+ VP- PARAMS: GAIN=1
    G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VIN+,VIN-),V(VP-,VIN-), V(VP+,VIN-))}
    .ENDS  VCM_CLAMP_OPAx376
    .SUBCKT VNSE_OPAx376 1 2 PARAMS: FLW=1 GLF=0.0473 RNV=66.6
    .MODEL DVN D KF={PWR(FLW,0.5)/1E11} IS=1.0E-16
    I1 0 7 10E-3
    I2 0 8 10E-3
    D1 7 0 DVN
    D2 8 0 DVN
    E1 3 6 7 8 {GLF}
    R1 3 0 1E9
    R2 3 0 1E9
    R3 3 6 1E9
    E2 6 4 5 0 10
    R4 5 0 {RNV}
    R5 5 0 {RNV}
    R6 3 4 1E9
    R7 4 0 1E9
    E3 1 2 3 4 1
    .ENDS  VNSE_OPAx376
    .SUBCKT VOS_DRIFT_OPAx376 VOS+ VOS- PARAMS: DC=-21.32E-06 POL=1 DRIFT=0.32E-06
    E1 VOS+ VOS- VALUE={DC+POL*DRIFT*(TEMP-27)}
    .ENDS  VOS_DRIFT_OPAx376
    .SUBCKT VOS_SRC_OPAx376 V+ V- REF+ REF-
    E1 V+ 1 TABLE {(V(REF+, V-))} =
    +(-.1, 1.1E-3)
    +(0.9, 1E-3)
    +(1, 0)
    +(4, 0)
    E2 1 V- TABLE {(V(V-, REF-))}=
    +(-0.1, 1E-4)
    +(1, 0)
    +(1.1, 0)
    .ENDS  VOS_SRC_OPAx376
    .SUBCKT ZO_SRC_OPAx376 VC+ VC- IOUT+ IOUT- PARAMS: GAIN=1667 IPOS=6.4E3 INEG=-10E3
    .ENDS  ZO_SRC_OPAx376
    Best regards, Art
