Other Parts Discussed in Thread: TLV3542
Hi, TI expert.
The customer is looking for a substitute with superior specifications to the OPAMP (LMV722MM) they are currently using.
The substitute is intended for upgrading the performance of the current area sensor.
The substitute should be capable of processing pulse signals with a width of 0.5μs or less.
• Supply Voltage: 5V
• Package: SSOP8 pin (0.65mm pitch), compatible with LMV722MM (https://www.ti.com/product/LMV722-N?keyMatch=LMV722MM/NOPB&tisearch=search-everything&usecase=OPN-ALT)
• Number of Circuits: 2 circuits
• Output Voltage Range: Full swing
• GBW: 100MHz or higher
Please refer to the above specifications and recommend a suitable substitute.
Thank you.
