Part Number: INA213
Other Parts Discussed in Thread: INA240
Dear all,
I use the component INA213BID in my application.
I observed that when I have no load, the component gets very hot (about 50°C / 323K with Tamb 24°C / 297K). The signal through the shunt resistor is 5V square wave, the component is powered at 3.3V.
I wanted to ask you if you have any ideas about the cause of this phenomenon.
Can the voltage difference between IN and V+ be a problem? I would like to test if I power the component at 5V (same voltage like the inputs) if the IC temperature will decrease.
Thank you very much for your support
Best regards
Andrea
