Other Parts Discussed in Thread: OPA210, OPA197, OPA192
Hello team,
I have a question about regarding thread above.
Could you suggest a device similar to the OPA227 with improved linearity on the negative side?
Masa
Hi Masa,
Without knowing anything else about your application, I would suggest you to consider using bipolar input OPA210 with better input common-mode voltage and rail-to-rail output voltage range. Other than this, you should consider one of our CMOS rai-to-rai input/output op amps like OPA192 or OPA197.
Hello Marek,
Understood. I will promote it to the customer.
Masa
