Part Number: TLV9102
I'm using the TLV9102 for various industrial AIO drivers. These drivers will not be disabled at any time.
Because of this, I want to consistently (and clearly) disable the SHDN (Shutdown) function of the operational amplifier.
According to the datasheet, the SHDN pin has a weak pull-up to the negative power supply line (V-). Is it possible to ensure a valid low signal by connecting the SHDN pin to the V- pin and grounding them together?
Or should I leave the SHDN pin floating?
