Other Parts Discussed in Thread: TLC139
Hello. We were told 5962-9096901M2A (TLC3704MFKB) was going obsolete and the recommended alternative is TLC3704QDRQ1.
While the output type and parameters all match very close, TLC3704QDRQ1 does not come in the same package as 5962-9096901M2A (TLC3704MFKB) , which is LCCC/20pin.
I tried to search but have not had luck finding an alternative that matches as close.
I did find 5962-87659012A (TLC374MFKB), but it is open-collector, open-drain output, less propagation delay time, and higher Iq per channel.
Do you have an alternative to 5962-9096901M2A (TLC3704MFKB) that is closer in the same package?
If not, could you tell me the compatibility of output types (push-pull vs open-collector, open drain)?
Thank you
