Part Number: OPA838
Other Parts Discussed in Thread: TINA-TI
following on from this post: https://e2e.ti.com/support/tools/simulation-hardware-system-design-tools-group/sim-hw-system-design/f/simulation-hardware-system-design-tools-forum/769211/tina-spice-opa838-the-opa838-tina-spice-model-has-occurred-floating-error-for-using-some-standard-spice
The model required a few more resistors to allow simulation in the latest version of LTSPICE. Model was verified with loaded open loop gain simulation
CIR file follows:
* OPA838
* (C) Copyright 2018 Texas Instruments Incorporated. All rights reserved.
** This model is designed as an aid for customers of Texas Instruments.
** TI and its licensors and suppliers make no warranties, either expressed
** or implied, with respect to this model, including the warranties of
** merchantability or fitness for a particular purpose. The model is
** provided solely on an "as is" basis. The entire risk as to its quality
** and performance is with the customer.
** Released by: WEBENCH(R) Design Center, Texas Instruments Inc.
* Part: OPA838
* Date: 06/29/2018
* Model Type: All In One
* Simulator: TINA
* Simulator Version: 9.0
* EVM Order Number: N/A
* EVM Users Guide: N/A
* Datasheet: Rev2 Nov16, 2016
* Notes:
* The following parameters are modeled: Aol,GBW,PM,
* Closed loop f_3db, peaking, Zincm,Zindiff,Vnoise, Inoise,
* PSRR,CMRR,Vos,Ib,Ios,Vos drift, Ib drift ,Ios drift , Isc,
* VOH,VOL,Zool,Zocl,Slew Rate,VIH,VIL, quiscent current,recovery time.
.subckt OPA838 VOUT VS- VIN+ VIN- PDBAR VS+
XI0 VS- VS+ VIN- VIN+ VOUT PDBAR VFA
.ends
.subckt VFA VEE VCC VINM VINP VOUT PD
XI0 VEE VCC VINM VINP VOUT PD VFA_HT5
XI5 NET35 VINP DiodeIdeal
V0 NET35 NET38 700e-3
XI6 NET33 NET38 DiodeIdeal
V1 NET33 VINM 700e-3
XI8 NET030 VINM DiodeIdeal
V3 NET030 NET023 700e-3
XI7 NET032 NET023 DiodeIdeal
V2 NET032 VINP 700e-3
.ends
.subckt ESDDIODES VCC VEE VIN VOUT PARAMS: VESDL=-700e-3 VESDH=-700e-3
XIDVIH NET12 NET16 DiodeIdeal
XIDVIL NET16 NET20 DiodeIdeal
R0 VIN NET16 1e-3
V0 NET16 VOUT 0
VESDL NET20 VEE {VESDL}
VESDH VCC NET12 {VESDH}
.ends ESDDIODES
.subckt VINRANGE3 SIGNAL1 SIGNAL2 VCC VEE VINM VINP PARAMS: SignalGain=1 VIL=100e-3 VIH=100e-3
XIDVIL NET13 NET074 DiodeIdeal
XIDVIH NET076 NET13 DiodeIdeal
FVIL2 SIGNAL2 VEE VIL {SignalGain}
FVIL1 SIGNAL1 VEE VIL {SignalGain}
FVIH1 VCC SIGNAL1 VIH {SignalGain}
FVIH2 VCC SIGNAL2 VIH {SignalGain}
E1 NET8 0 VINM 0 1
E0 NET6 0 VINP 0 1
VIL NET074 VEE {VIL}
VIH VCC NET076 {VIH}
R7 NET8 NET13 1
R6 NET6 NET13 1
.ends VINRANGE3
.subckt ZIN IN1 IN2 OUT1 OUT2 PARAMS: R5=100e-3 R4=100e-3 C3=50e-15 C2=50e-15
+ C1=50e-15 R2=10e9 R1=10e9 R3=1e9
R5 IN2 OUT2 {R5}
R4 IN1 OUT1 {R4}
C3 OUT1 OUT2 {C3}
C2 OUT2 0 {C2}
C1 OUT1 0 {C1}
GR2 OUT2 0 OUT2 0 {1/R2}
GR1 0 OUT1 0 OUT1 {1/R1}
GR3 OUT1 OUT2 OUT1 OUT2 {1/R3}
.ends ZIN
.subckt DOMPOLE A B C PARAMS: R2=1e-3 R1=2.653e6 C2=1e-15 C1=10e-12
R2 NET7 A {R2}
R1 B A {R1}
C2 NET7 C {C2}
C1 A B {C1}
.ends DOMPOLE
.subckt PHASEDELAY A B VIN VOUT PARAMS: R1=1 R2=1e9 C1=1e-15 C2=1e-15 Gain=1 L=1e-12
R5 VOUT NET026 1e-3
R3 NET15 NET024 1e-3
R1 NET27 NET15 {R1}
R4 NET15 A 1e9
R2 VOUT B {R2}
C1 NET024 A {C1}
C2 NET026 B {C2}
E0 NET27 0 VIN 0 {Gain}
L0 NET15 VOUT {L}
.ends PHASEDELAY
.subckt NONDOMPOLE C VIN VOUT PARAMS: L=1e-12 Gain=1 C=226.7e-12 Rp=1e9 Rs=1
L0 NET020 VOUT {L}
E0 NET4 0 VIN 0 {Gain}
C1 NET019 C {C}
R3 VOUT C {Rp}
R2 VOUT NET019 1e-3
R1 NET020 NET4 {Rs}
.ends NONDOMPOLE
.subckt ANALOG_BUFFER VOUT VIN
R0 VIN 0 1e9
R1 VOUT 0 1e9
E0 VOUT 0 VIN 0 1
.ends ANALOG_BUFFER
.subckt OUTPUTCIR PD VCC VCCMAIN VEE VEEMAIN VIN VOUT
XI25 NET75 NET092 OutputCir_IscDiodeIdeal PARAMS: IS=10e-15 N=50e-3
XI23 NET79 NET76 OutputCir_IscDiodeIdeal PARAMS: IS=10e-15 N=50e-3
*XIVOL VOL VEE VIMONINV OutputCir_VOHVOL PARAMS: VSUPPLYREF=0 VOUTvsIOUT_X1=
*+ {ABS(0)} VOUTvsIOUT_Y1=0.1 VOUTvsIOUT_X2= {ABS(-19e-3)} VOUTvsIOUT_Y2=0.131
*XIVOH VCC VOH VIMON OutputCir_VOHVOL PARAMS: VSUPPLYREF=5 VOUTvsIOUT_X1= {ABS(0)}
*+ VOUTvsIOUT_Y1=4.9 VOUTvsIOUT_X2= {ABS(17e-3)} VOUTvsIOUT_Y2=4.59
*XISOURCEVLIMIT NET064 NET76 VCC VEE OutputCir_IscVlimit PARAMS: RIsc=1 IscVsVsupply_X1=3
*+ IscVsVsupply_Y1= {ABS(37.5e-3)} IscVsVsupply_X2=5 IscVsVsupply_Y2= {ABS(37.5e-3)}
*XISINKVLIMIT NET047 NET092 VCC VEE OutputCir_IscVlimit PARAMS: RIsc=1 IscVsVsupply_X1=3
*+ IscVsVsupply_Y1= {ABS(-50e-3)} IscVsVsupply_X2=5 IscVsVsupply_Y2= {ABS(-50e-3)}
XIVOL VOL VEE VIMONINV OutputCir_VOL
XI14 NET070 NET15 DiodeIdeal
XI15 NET068 VOL DiodeIdeal
XI0 VCCMAIN VEEMAIN VIMON PD OutputCir_ILOAD
XI6 NET22 NET0100 0 NET043 VCC VEE RECOVERYSIGNAL OutputCir_RecoveryAssist
XAHDLI43 NET055 NET054 RECOVERYSIGNAL VCC VEE HPA_OR2
XAHDLI41 VOUT NET067 NET055 VCC VEE HPA_COMP_IDEAL
XAHDLI42 NET059 VOUT NET054 VCC VEE HPA_COMP_IDEAL
HVIMONINV VIMONINV 0 VCURSINKDETECT 1
HVIMON VIMON 0 VCURSOURCEDETECT 1
RVIMONINV VIMONINV 0 1e9
RVIMON VIMON 0 1e9
RISC NET092 NET15 1
XI11 NET76 NET15 ANALOG_BUFFER
XI2 NET22 VIN ANALOG_BUFFER
VPROBE3 NET070 VOH 0
VPROBE2 NET043 NET0100 0
VTRIGGERVOL NET059 VOL 10e-3
VTRIGGERVOH VOH NET067 10e-3
*no idea where these two voltages where meant to connect
V3 NET79 NET047 0
V4 NET75 NET064 0
RFIX1 NET047 NET092 1e12
RFIX2 NET064 NET76 1e12
VPROBE4 NET068 NET15 0
VCURSOURCEDETECT NET15 NET34 0
VCURSINKDETECT VOUT NET34 0
VPROBE1 NET53 NET17 0
XI1 NET53 NET22 VIMON OutputCir_Rout PARAMS: Ro_Iout_0A=3.76e+05 RIsc=1 Isc=37.5e-3 Islope_const=10u
COUT NET22 NET0100 40e-6
ROUTMINOR NET0100 NET17 5.7354
LOUT1 NET17 NET092B 300e-9
LOUT2 NET092B NET092 100e-9
CBYP NET17 NET092A 100e-12
RBYP NET092A NET092B 150
RP NET092 NET0146 103
CP NET0146 0 2.7e-12
.ends OUTPUTCIR
.SUBCKT OutputCir_VOH A B C
E1 A B TABLE { V(C) } =
+ (0, 0.1)
+ (0.004398167, 0.101)
+ (0.004990522, 0.115)
+ (0.005727892, 0.132)
+ (0.006644229, 0.152)
+ (0.007775451, 0.177)
+ (0.009165461, 0.208)
+ (0.010861992, 0.246)
+ (0.012924627, 0.291)
+ (0.015409226, 0.345)
+ (0.018368556, 0.410)
+ (0.021854651, 0.486)
+ (0.025888259, 0.575)
+ (0.030440626, 0.679)
+ (0.035458333, 0.798)
+ (37.5m, 1)
+ (38.5m, 2)
+ (40.0m, 3)
+ (41.0m, 4)
+ (42.0m, 5)
.ENDS
.SUBCKT OutputCir_VOL A B C
+ (0, 0.027)
+ (0.004533833, 0.027)
+ (0.005164196, 0.032)
+ (0.005957685, 0.037)
+ (0.006949841, 0.044)
+ (0.008193846, 0.052)
+ (0.009749299, 0.062)
+ (0.011686039, 0.075)
+ (0.014100656, 0.090)
+ (0.017096732, 0.109)
+ (0.020820626, 0.131)
+ (0.025392196, 0.160)
+ (0.030998669, 0.195)
+ (0.037762424, 0.241)
+ (0.045708333, 0.306)
+ (47.5m, 0.5000)
+ (50.0m, 1.0000)
+ (51.0m, 2.0000)
+ (52.0m, 3.0000)
+ (53.0m, 4.0000)
+ (54.0m, 5.0000)
.ENDS
.subckt RECOVERYCIRCUIT A B VCC VEE PARAMS: VRecL=-10e-3 VRecH=-10e-3
XI2 NET8 NET014 DiodeIdeal
XI3 NET014 NET9 DiodeIdeal
VBRIDGE NET014 A 0
VPROBE A B 0
VRECL NET9 VEE {VRecL}
VRECH VCC NET8 {VRecH}
.ends RECOVERYCIRCUIT
.subckt VFA_HT5 VEE VCC VINM VINP VOUT PD
***step1
*Rincm=R1=R2,Cincm=C1=C2,Rindiff=R3,Cindiff=C3
XI53 VINP VINM NET1 NET2 ZIN PARAMS: R5=100e-3 R4=100e-3
+ C3=0.8e-12 C2=1.3e-12 C1=1.3e-12 R2=100e3 R1=100e3 R3=50e3
XI17 NET1 NET11 Vnoise PARAMS: X=0.01 Y=191.1e-9 Z=1.9e-9
XI18 NET11 0 Inoise PARAMS: X=0.01 Y=131e-12 Z=1.3e-12
XI63 NET2 0 Inoise PARAMS: X=0.01 Y=131e-12 Z=1.3e-12
XI59 NET21 NET11 Vinoffset PARAMS: TA=25 VOS=15e-6 DRIFT=0.3e-6
XI60 VINP_INT VINM_INT Ibias PARAMS: Choice=1 Ibias=-1.8e-6 Ioffset=10e-9 TA=25
+ IbiasDrift=10e-9 IoffsetDrift=10e-12 Ibiasp=-1.795e-6 Ibiasm=-1.805e-6
XI40 VCC VEE POWER VEE_INT VCC_INT Iq PARAMS: IOFF=2e-6 ION_X1=0 ION_Y1=0.95e-3
+ ION_X2=1.8 ION_Y2=0.95e-3 ION_X3=3.3 ION_Y3=0.95e-3 ION_X4=5.5 ION_Y4=0.95e-3
***step2
XI19 VCC_INT VEE_INT NET2 NET12 PSRR PARAMS: PSRRP_DC=-120 PSRRP_f3dB=10.03e3
+ PSRRN_DC=-120 PSRRN_f3dB=10.08e3
XI66 HIGHZ NET56 VCC_INT VEE_INT NET22 NET21 VINRANGE3 PARAMS: SignalGain=1 VIL=-0.2 VIH=1.2
*Isc-source and sink current
***step3 & step4
XI21 NET12 NET22 NET12 CMRR PARAMS: CMRR_DC=-106 CMRR_f3dB=10e3 CMRR_f3dB_FudgeFactor=1
XI52 VINP_INT VINM_INT NET32 NET31 VEE_INT VCC_INT POWER GmItail PARAMS: Choice=11
+ Gm=9.021e-1 SBF=1 ITAILMAX_X1=3 ITAILMAX_Y1=100e-3 ITAILMAX_X2=5 ITAILMAX_Y2=100e-3
+ ITAILMIN_X1=3 ITAILMIN_Y1=100e-3 ITAILMIN_X2=5 ITAILMIN_Y2=100e-3
XI58 HIGHZ NET32 0 DOMPOLE PARAMS: R2=1e-3 C2=1e-15 R1=2.482e6 C1=4.985e-10
**The Gain = VCVS3 Gain, RS=R10, L=L1, C=C2, Rp=R13
XI26 0 NET51 NET61 NONDOMPOLE PARAMS: Gain=1.18 Rs=60 L=53.2e-9 C=1.7e-12 Rp=340
**The Gain=VCVS2 gain, R1=R4, C1=C3, L=L3, C2=C4, R2=R6
XI85 0 0 NET61 NET71 PHASEDELAY PARAMS: R1=10 C1=21.55e-12 L=6.2e-9 C2=140.7e-12 R2=10 Gain=2
*VOH and VOL
***step5
XI30 POWER VCC_INT VCC VEE_INT VEE NET71 VOUT OUTPUTCIR
***step7
XI28 NET41 NET51 VCC_INT VEE_INT RECOVERYCIRCUIT PARAMS: VRecL=-0.1 VRecH=-0.1
XI67 VCC_INT VEE_INT NET21 VINP_INT ESDDIODES PARAMS: VESDL=-700e-3 VESDH=-700e-3
XI68 VCC_INT VEE_INT NET22 VINM_INT ESDDIODES PARAMS: VESDL=-700e-3 VESDH=-700e-3
VPROBE2 HIGHZ NET41 0
*VPROBE2 HIGHZ NET41
VDOMPOLEBIAS NET32 0 0
VPROBE1 NET31 HIGHZ 0
*VPROBE1 NET31 HIGHZ
R0 NET56 0 1e3
R14 VCC_INT PD 10e6
XAHDLINV3 PD PDINV VCC_INT VEE_INT HPA_INV_IDEAL
XAHDLINV1 PDINV POWER VCC_INT VEE_INT HPA_INV_IDEAL
XI13 VEE_INT VEE ANALOG_BUFFER
XI12 VCC_INT VCC ANALOG_BUFFER
.ends VFA_HT5
.SUBCKT HPA_OR2 1 2 3 VDD VSS
E1 4 0 VALUE={IF(((V(1)<(V(VDD)+V(VSS))/2 ) & (V(2)<(V(VDD)+V(VSS))/2 )),V(VSS),V(VDD))}
R1 4 3 1
C1 3 0 1e-12
.ENDS
.SUBCKT HPA_INV_IDEAL 1 2 VDD VSS
E1 2 0 VALUE = { IF( V(1)> (V(VDD)+V(VSS))/2, V(VSS), V(VDD) ) }
.ENDS
.SUBCKT HPA_COMP_IDEAL INP INN OUT VDD VSS
E1 OUT 0 VALUE = { IF( (V(INP) > V(INN)), V(VDD), V(VSS) ) }
.ENDS
.SUBCKT AVG VIN1 VIN2 VOUT
E1 VOUT 0 VALUE = { ( V(VIN1) + V(VIN2) ) / 2 }
.ENDS
.SUBCKT CMRR A B C PARAMS:
+ CMRR_DC = -100
+ CMRR_f3dB = 50e3
+ CMRR_f3dB_FudgeFactor = 3.4
.PARAM CMRR = {0-CMRR_DC}
.PARAM FCMRR = {CMRR_f3dB * CMRR_f3dB_FudgeFactor}
X1 A B C 0 CMRR_NEW PARAMS: CMRR = {CMRR} FCMRR = {FCMRR}
.ENDS
.SUBCKT DiodeIdeal NEG POS
G1 POS NEG VALUE = { IF ( V(POS,NEG) <= 0 , 0, V(POS,NEG)*0.01G ) }
R0 POS NEG 1000G
.ENDS
.SUBCKT DomPoleBias VIN1 VIN2 VOUT
E1 VOUT 0 VALUE = { ( V(VIN1) + V(VIN2) ) / 2 * 1/2}
R1 VOUT 0 1G
.ENDS
.SUBCKT GmItail Vinp Vinm Ioutp Ioutm VEE VCC PD PARAMS:
+ Choice = 2
+ Gm = 3.77e-2
+ SBF = 1
+ ITAILMAX_X1 = { 3.0 }
+ ITAILMAX_Y1 = { 10m }
+ ITAILMAX_X2 = { 5.0 }
+ ITAILMAX_Y2 = { 10m }
+ ITAILMIN_X1 = { 3.0 }
+ ITAILMIN_Y1 = { 10m }
+ ITAILMIN_X2 = { 5.0 }
+ ITAILMIN_Y2 = { 10m }
.PARAM Choice1 = { IF ( Choice == 1, 1, 0 ) }
.PARAM Choice2 = { IF ( Choice == 2, 1, 0 ) }
.PARAM Choice3 = { IF ( Choice == 3, 1, 0 ) }
.PARAM Choice11 = { IF ( Choice == 11, 1, 0 ) }
X1 PD PDINV VCC VEE LOGIC1 0 DLSINV
VLOGIC1 LOGIC1 0 1
.PARAM ITAILMAX_SLOPE =
+ { ( ITAILMAX_Y2 - ITAILMAX_Y1 ) / ( ITAILMAX_X2 - ITAILMAX_X1 ) }
.PARAM ITAILMAX_INTCP =
+ { ITAILMAX_Y1 - ITAILMAX_SLOPE * ITAILMAX_X1 }
EITAILMAX ITAILMAX 0 VALUE =
+ { ITAILMAX_SLOPE * V(VCC,VEE) + ITAILMAX_INTCP }
.PARAM ITAILMIN_SLOPE =
+ { ( ITAILMIN_Y2 - ITAILMIN_Y1 ) / ( ITAILMIN_X2 - ITAILMIN_X1 ) }
.PARAM ITAILMIN_INTCP =
+ { ITAILMIN_Y1 - ITAILMIN_SLOPE * ITAILMIN_X1 }
EITAILMIN ITAILMIN 0 VALUE =
+ { ITAILMIN_SLOPE * V(VCC,VEE) + ITAILMIN_INTCP }
G1 IOUTP IOUTM VALUE = { ( 1-V(PDINV) ) * (
+ Choice1 * ( LIMIT ( Gm * V(VINP,VINM) , -V(ITAILMIN), V(ITAILMAX) ) ) +
+ Choice2 * ( Gm * (V(ITAILMAX)/Gm) * TANH( V(VINP,VINM) / (V(ITAILMAX)/Gm) ) ) +
+ Choice3 * ( Gm * V(VINP,VINM) / ( 1 + Gm/V(ITAILMAX) * ABS( V(VINP,VINM) ) ) ) +
+ Choice11 * ( LIMIT ( ( Gm * EXP ( LIMIT ( SBF * ABS(V(VINP,VINM)) , -LOG(1E100), LOG(1E100) ) ) )
+ * V(VINP,VINM) , -V(ITAILMIN), V(ITAILMAX) ) ) +
+ 0 ) }
.ENDS
.SUBCKT Ibias VINP VINM PARAMS:
+ Choice = 1
+ Ibias = -10u
+ Ioffset = 150n
+ TA = 25
+ IbiasDrift = 0
+ IoffsetDrift = 0
+ Ibiasp = -9.925u
+ Ibiasm = -10.075u
.PARAM Ib = { Choice1 * Ibias + Choice2 * (Ibiasp + Ibiasm)/2 }
.PARAM Io = { Choice1 * Ioffset + Choice2 * ABS(Ibiasp - Ibiasm) }
EIb Ib 0 VALUE = { IbiasDrift * TEMP + ( Ib - IbiasDrift * TA ) }
EIo Io 0 VALUE = { IoffsetDrift * TEMP + ( Io - IoffsetDrift * TA ) }
GIbp VINP 0 VALUE = { V(Ib) + V(Io)/2 }
GIbm VINM 0 VALUE = { V(Ib) - V(Io)/2 }
.ENDS
.SUBCKT Inoise A B PARAMS:
+ X = { 1m }
+ Y = { 100f }
+ Z = { 1f }
X1 A B FEMT PARAMS: NLFF = { Y/1f } FLWF = { X } NVRF = { Z/1f }
.ENDS
.subckt Iq VCCmain VEEmain PD VEE VCC PARAMS:
+ IOFF = { 1n }
+ ION_X1 = { 0.0 }
+ ION_Y1 = { 1m }
+ ION_X2 = { 1.6 }
+ ION_Y2 = { 1m }
+ ION_X3 = { 1.9 }
+ ION_Y3 = { 1m }
+ ION_X4 = { 12.0 }
+ ION_Y4 = { 1m }
EION_SEG1 ION_SEG1 0 VALUE = { IF ( V(VCC,VEE) <= ION_X2, 1, 0 ) }
EION_SEG2 ION_SEG2 0 VALUE = { IF ( V(VCC,VEE) > ION_X2 & V(VCC,VEE) <= ION_X3, 1, 0 ) }
EION_SEG3 ION_SEG3 0 VALUE = { IF ( V(VCC,VEE) > ION_X3 , 1, 0 ) }
.PARAM ION_SEG1_SLOPE = { ( ION_Y2 - ION_Y1 ) / ( ION_X2 - ION_X1 ) }
.PARAM ION_SEG1_INTCP = { ION_Y1 - ION_SEG1_SLOPE * ION_X1 }
.PARAM ION_SEG2_SLOPE = { ( ION_Y3 - ION_Y2 ) / ( ION_X3 - ION_X2 ) }
.PARAM ION_SEG2_INTCP = { ION_Y2 - ION_SEG2_SLOPE * ION_X2 }
.PARAM ION_SEG3_SLOPE = { ( ION_Y4 - ION_Y3 ) / ( ION_X4 - ION_X3 ) }
.PARAM ION_SEG3_INTCP = { ION_Y3 - ION_SEG3_SLOPE * ION_X3 }
EION ION 0 VALUE = { V(ION_SEG1) * ( ION_SEG1_SLOPE * V(VCC,VEE) + ION_SEG1_INTCP ) +
+ V(ION_SEG2) * ( ION_SEG2_SLOPE * V(VCC,VEE) + ION_SEG2_INTCP ) +
+ V(ION_SEG3) * ( ION_SEG3_SLOPE * V(VCC,VEE) + ION_SEG3_INTCP ) }
VLOGIC1 LOGIC1 0 1
G1 VCCMAIN VEEMAIN VALUE = { V(ION) * ( 1-V(PDINV) ) + IOFF * V(PDINV) }
.ends
.SUBCKT OutputCir_ILOAD VDD VSS VIMON PD
X1 PD PDINV VDD VSS LOGIC1 0 DLSINV
VLOGIC1 LOGIC1 0 1
G1 VDD 0 VALUE = {IF(V(VIMON) >= 0, V(VIMON)*( 1-V(PDINV) ), 0)}
G2 VSS 0 VALUE = {IF(V(VIMON) < 0, V(VIMON)*( 1-V(PDINV) ), 0)}
.ENDS
.SUBCKT OutputCir_IscDiodeIdeal NEG POS PARAMS:
+ IS = 1E-14
+ N = 50m
G1 POS NEG_INT VALUE = { IF ( V(POS,NEG_INT) <= 0 , IS,
+ IS * ( EXP ( V(POS,NEG_INT)/25m * 1/N ) - 0 ) ) }
V1 NEG_INT NEG {-N*0.8}
.ENDS
.SUBCKT OutputCir_IscVlimit A B VCC VEE PARAMS:
+RIsc = { 1 }
+IscVsVsupply_X1 = { 3.0 }
+IscVsVsupply_Y1 = { 75m }
+IscVsVsupply_X2 = { 5.0 }
+IscVsVsupply_Y2 = { 100m }
.PARAM IscVsVsupply_SLOPE =
+ { ( IscVsVsupply_Y2 - IscVsVsupply_Y1 ) / ( IscVsVsupply_X2 - IscVsVsupply_X1 ) }
.PARAM IscVsVsupply_INTCP =
+ { IscVsVsupply_Y1 - IscVsVsupply_SLOPE * IscVsVsupply_X1 }
EIscVsVsupply IscVsVsupply 0 VALUE =
+ { IscVsVsupply_SLOPE * V(VCC,VEE) + IscVsVsupply_INTCP }
E1 A B VALUE = { V(IscVsVsupply) * RIsc }
.ENDS
.SUBCKT OutputCir_RecoveryAssist VINP VINM IOUTP IOUTM VCC VEE RecoverySignal
X1 RecoverySignal RS VCC VEE LOGIC1 0 DLS
VLOGIC1 LOGIC1 0 1
G1 IOUTP IOUTM VALUE = { LIMIT ( 1m * V(VINP,VINM) * V(RS) , -100m, 100m ) }
.ENDS
.SUBCKT OutputCir_Rout B A VIMON PARAMS:
+ Ro_Iout_0A = 100
+ RIsc = 1
+ Isc = 100m
+ Islope_const = 1/100
.PARAM Islope = { Islope_const * Isc }
G1 A B VALUE = { V(A,B) * 1 / ( (Ro_Iout_0A - RIsc) * Islope / ( Islope + ABS(V(VIMON)) ) ) }
.ENDS
.SUBCKT OutputCir_VOHVOLDiodeIdeal NEG POS
R0 POS NEG 1000G
.ENDS
.SUBCKT OutputCir_VOHVOL A B C PARAMS:
+ VSUPPLYREF = {2.5}
+ VOUTvsIOUT_X1 = { ABS(0) }
+ VOUTvsIOUT_Y1 = { 2.4 }
+ VOUTvsIOUT_X2 = { ABS(100m) }
+ VOUTvsIOUT_Y2 = { 2.1 }
.PARAM VDROPvsIOUT_X1 = { VOUTvsIOUT_X1 }
.PARAM VDROPvsIOUT_Y1 = { ABS(VSUPPLYREF-VOUTvsIOUT_Y1) }
.PARAM VDROPvsIOUT_X2 = { VOUTvsIOUT_X2 }
.PARAM VDROPvsIOUT_Y2 = { ABS(VSUPPLYREF-VOUTvsIOUT_Y2) }
.PARAM VDROPvsIOUT_SLOPE =
+ { ( VDROPvsIOUT_Y2 - VDROPvsIOUT_Y1 ) / ( VDROPvsIOUT_X2 - VDROPvsIOUT_X1 ) }
.PARAM VDROPvsIOUT_INTCP =
+ { VDROPvsIOUT_Y1 - VDROPvsIOUT_SLOPE * VDROPvsIOUT_X1 }
EVDROPvsIOUT VDROPvsIOUT 0 VALUE =
+ { VDROPvsIOUT_SLOPE * V(C) + VDROPvsIOUT_INTCP }
E1 A B VALUE = { V(VDROPvsIOUT) }
.ENDS
.SUBCKT PSRR VDD VSS A B PARAMS:
+ PSRRP_DC = -100
+ PSRRP_f3dB = 100k
+ PSRRN_DC = -90
+ PSRRN_f3dB = 90k
.PARAM PSRRP = {0-PSRRP_DC}
.PARAM PSRRN = {0-PSRRN_DC}
.PARAM FPSRRP = {PSRRP_f3dB}
.PARAM FPSRRN = {PSRRN_f3dB}
X1 VDD VSS A B 0 PSRR_DUAL_NEW PARAMS:
+ PSRRP = {PSRRP} FPSRRP = {FPSRRP}
+ PSRRN = {PSRRN} FPSRRN = {FPSRRN}
.ENDS
.SUBCKT RecoveryCircuit_DiodeIdeal NEG POS
R0 POS NEG 1000G
.ENDS
.SUBCKT Vinoffset POS NEG PARAMS:
+ TA = 25
+ VOS = 500u
+ DRIFT = 10u
E1 POS NEG VALUE = { DRIFT * TEMP + ( VOS - DRIFT * TA ) }
.ENDS
.SUBCKT Vinrange_DiodeIdeal NEG POS
G1 POS NEG VALUE = { IF ( V(POS,NEG) <= 0 , 0, V(POS,NEG)*100k ) }
R0 POS NEG 1000G
.ENDS
.SUBCKT Vnoise A B PARAMS:
+ X = { 1m }
+ Y = { 100n }
+ Z = { 5n }
X1 A B VNSE PARAMS: NLF = { Y/1n } FLW = { X } NVR = { Z/1n }
.ENDS
.SUBCKT VNSE 1 2 PARAMS: NLF = 10 FLW = 4 NVR = 4.6
.PARAM GLF={PWR(FLW,0.25)*NLF/1164}
.PARAM RNV={1.184*PWR(NVR,2)}
.MODEL DVN D KF={PWR(FLW,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVN
D2 8 0 DVN
E1 3 6 7 8 {GLF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNV}
R5 5 0 {RNV}
R6 3 4 1E9
R7 4 0 1E9
E3 1 2 3 4 1
C1 1 0 1E-15
C2 2 0 1E-15
C3 1 2 1E-15
.ENDS
.SUBCKT FEMT 1 2 PARAMS: NLFF = 0.1 FLWF = 0.001 NVRF = 0.1
.PARAM GLFF={PWR(FLWF,0.25)*NLFF/1164}
.PARAM RNVF={1.184*PWR(NVRF,2)}
.MODEL DVNF D KF={PWR(FLWF,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVNF
D2 8 0 DVNF
E1 3 6 7 8 {GLFF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNVF}
R5 5 0 {RNVF}
R6 3 4 1E9
R7 4 0 1E9
G1 1 2 3 4 1E-6
C1 1 0 1E-15
C2 2 0 1E-15
C3 1 2 1E-15
.ENDS
.SUBCKT PSRR_SINGLE VDD VSS VI VO GNDF PARAMS: PSRR = 130 FPSRR = 1.6
.PARAM PI = 3.141592
.PARAM RPSRR = 1
.PARAM GPSRR = {PWR(10,-PSRR/20)/RPSRR}
.PARAM LPSRR = {RPSRR/(2*PI*FPSRR)}
G1 GNDF 1 VDD VSS {GPSRR}
R1 1 2 {RPSRR}
L1 2 GNDF {LPSRR}
E1 VO VI 1 GNDF 1
C2 VDD VSS 10P
.ENDS
.SUBCKT PSRR_SINGLE_NEW VDD VSS VI VO GNDF PARAMS: PSRR = 130 FPSRR = 1.6
.PARAM RPSRR = 1
R1 1 2 {RPSRR}
L1 2 GNDF {LPSRR}
EA 101 GNDF 1 GNDF 1
GRA 101 102 VALUE = { V(101,102)/1e6 }
*ADD to fix floating node error
RA 102 GNDF 1e12
CA 102 GNDF 1e3
EB 1 1a VALUE = {V(102,GNDF)}
E1 VO VI 1a GNDF 1
C2 VDD VSS 10P
.ENDS
.SUBCKT PSRR_DUAL VDD VSS VI VO GNDF
+ PARAMS: PSRRP = 130 FPSRRP = 1.6
+ PSRRN = 130 FPSRRN = 1.6
.PARAM RPSRRP = 1
.PARAM GPSRRP = {PWR(10,-PSRRP/20)/RPSRRP}
.PARAM LPSRRP = {RPSRRP/(2*PI*FPSRRP)}
.PARAM RPSRRN = 1
.PARAM GPSRRN = {PWR(10,-PSRRN/20)/RPSRRN}
.PARAM LPSRRN = {RPSRRN/(2*PI*FPSRRN)}
G1 GNDF 1 VDD GNDF {GPSRRP}
R1 1 2 {RPSRRP}
L1 2 GNDF {LPSRRP}
G2 GNDF 3 VSS GNDF {GPSRRN}
R2 3 4 {RPSRRN}
L2 4 GNDF {LPSRRN}
E1 VO VI VALUE = {V(1,GNDF) + V(3,GNDF)}
C3 VDD VSS 10P
.ENDS
.SUBCKT PSRR_DUAL_NEW VDD VSS VI VO GNDF
.PARAM RPSRRP = 1
.PARAM RPSRRN = 1
R1 1 2 {RPSRRP}
L1 2 GNDF {LPSRRP}
RA 102 GNDF 1e12
CA 102 GNDF 1e3
R2 3 4 {RPSRRN}
L2 4 GNDF {LPSRRN}
EC 301 GNDF 3 GNDF 1
GRC 301 302 VALUE = { V(301,302)/1e6 }
*add to fix floating node error
RC 302 GNDF 1e12
CC 302 GNDF 1e3
ED 3 3a VALUE = {V(302,GNDF)}
E1 VO VI VALUE = {V(1a,GNDF) + V(3a,GNDF)}
C3 VDD VSS 10P
.ENDS
.SUBCKT CMRR_OLD VI VO VX GNDF PARAMS: CMRR = 130 FCMRR = 1.6K
.PARAM RCMRR = 1
.PARAM GCMRR = {PWR(10,-CMRR/20)/RCMRR}
.PARAM LCMRR = {RCMRR/(2*PI*FCMRR)}
G1 GNDF 1 VX GNDF {GCMRR}
R1 1 2 {RCMRR}
L1 2 GNDF {LCMRR}
E1 VI VO 1 GNDF 1
.ENDS
.SUBCKT CMRR_NEW VI VO VX GNDF PARAMS: CMRR = 130 FCMRR = 1.6K
.PARAM RCMRR = 1
R1 1 2 {RCMRR}
L1 2 GNDF {LCMRR}
GRA 101 102 VALUE = {V(101,102)/1e6}
RA 102 GNDF 1e12
CA 102 GNDF 1e3
E1 VI VO 1a GNDF 1
.ENDS
.SUBCKT DLS 1 2 VDD_OLD VSS_OLD VDD_NEW VSS_NEW
E1 3 0 VALUE = { IF( V(1) < (V(VDD_OLD)+V(VSS_OLD))/2, V(VSS_NEW), V(VDD_NEW) ) }
R1 3 2 1
C1 2 0 1p
.ENDS
.SUBCKT DLSINV 1 2 VDD_OLD VSS_OLD VDD_NEW VSS_NEW
E1 3 0 VALUE = { IF( V(1) > (V(VDD_OLD)+V(VSS_OLD))/2, V(VSS_NEW), V(VDD_NEW) ) }
R1 3 2 1
C1 2 0 1p
.ENDS
.SUBCKT SWITCH_IDEAL A B C PARAMS:
+ Ron = 100m
+ Roff = 0.1G
G1 A B VALUE = { V(A,B) * 1 / ( Roff/2 * TANH( 0 - ( 20*V(C) - 5 ) ) + Roff/2 + Ron ) }
R1 A 0 1000G
R2 B 0 1000G
.ENDS
.MODEL VINRANGE_DIDEAL D N=1m
.MODEL RECOVERYCIRCUIT_DIDEAL D N=1m
.MODEL OUTPUTCIR_ISC_DIDEAL D N=0.1m
.MODEL OUTPUTCIR_VOHVOL_DIDEAL D N=1m
.MODEL DBASIC D
