Other Parts Discussed in Thread: LM339, LM339B, LM339LV, TL331, TL331B, TL331LV
Hi team,
My customer is looking for 4ch comparator, they would need the spec is similar to LM393, could you please share some suggestion to us which to use? Thank you.
Thank you, Clemens! Correct, as usual!
And the equivalent single would be the TL331 / TL331B / TL331LV.
As Clemens mentioned, we would recommend the "B" versions, as some of the present, and future non-B's will be based off of the "B" design under PCN.
As with any design change, changing to the new device should be tested over a limited test run to insure full compatibility.
