TLV333: Low-Side Current Shunt Op-Amp Circuit to Single-Ended ADC for Cost-Optimized Monitor
Part Number: TLV333
Hello All,
I am looking for; https://www.ti.com/lit/an/sbaa353a/sbaa353a.pdf?ts=1712035145515&ref_url=https%253A%252F%252Fwww.google.com%252F
Low-Side Current Shunt Op-Amp Circuit to Single-Ended ADC for Cost-Optimized Monitor curcuit as shown;
This curcit is excatly what I need, but I have an one problem here, I want to make my voltage supply of LOAD +24V not +15V..
Is this curcuit okay for +24V load or am I need to look another TLV zero-drift type amplifier?
And if you have more suggestion about Current Shunt Monitoring please sahre with me.
  • For as long as the Rsh is referenced to the ground, the circuit will be configured for the low-side current measurement where Vcm =~Ish*Rsh.  Thus, for as long as the 0< Vcm <10.6mV (Ish<10.6A), the circuit will work properly.  Therefore, it does NOT matter what supply voltage you use to bias the LOAD.
