Hi Team
I am using the AMC1301DWVR to sense AC voltage. We are designing an inverter whose output AC voltage is 240 volts. This voltage, we are trying to sense by using AMC1301. A circuit diagram is given below.
Can someone check this circuit and let me know if I am good to use this circuit for AC sensing?
Hi Hariom,
A few things:
Thanks.
Hi Saleh
As per your suggestion, i made bit modification to circuit. I have done simulation and proof of concept for the following circuit, and I am getting the expected results. But I want to understand how the AC signal is amplifying in this circuit since we are not giving any negative supply to the iso-amp.
Hi Hariom,
You'll probably want the below resistors to make the filter effective.
Is the 240V that you mention rms or peak. Assuming 240Vrms, the peak voltage across the device inputs right now is: 240V*1.41*(1k /1241k) = 273mV. The linear range of the inputs of the device is +-250mV.
I can't give details on the inner-workings of the device, other than what's shown in the datasheet, without some NDA's.
Thanks.
