Hi TI
i use VCA5807 to connect MCU by SPI interface, i found the SDOUT no response when i entry SPI read/write test, i key command but read value always no meet write! so i check log from UART of MCU
i write : 0x04ef, but read alwayse is 0xf5f5
the SDOUT (pin.83) alwayse keep low when i use scope to measured it! in the meantime i check SDIN and CLK work is normal, could you have some suggestions or comments?
