ISO224: Could you tell me the IC you recommend?
Part Number: ISO224
Other Parts Discussed in Thread: AMC1350
I have any questions.
1) Does TI have isolation products with the specifications listed below?
 ・Primary side input voltage range is ±5V or more
1st-2nd order voltage resistance: AC1500V 60Hz for 1 minute
AC input possible (commercial frequency 60Hz must be measurable)
Satisfies the operating temperature range -25 to 85
Target range of secondary side output voltage is approximately ±5V to ±10V.
I found ISO224, but please let me know if there is anything else.
2)Which product has the same or higher specs as the AD204KY(ADI)?
Nishie
  • Hi Nishie,
    Thank you for your interest in our isolation parts. Who is your customer and what is their system?
    1. Could you use a resistor divider on your input? This would give more options from our device portfolio. The ISO224 is our product with the highest input range.
    2. I would recommend the AMC1350 as the best replacement product.
    Eva
  • Hi Eva-san,
    Thank you for your support.
    Customer names and applications cannot be listed in E2E. If necessary, we will notify you by private message.
    1) I will check with the customer if a resistance divider can be used.
    Nishie
  • Hi Nishie-san,
    Got it, please let me know if there are any more questions.
    Eva
  • Hi Eva-san,
    OK.
    I will let you know after the customer replies.
    Nishie
