Part Number: THS4551
Other Parts Discussed in Thread: ADS5294
I want to convert a 450m swing single-ended signal 3.5Mhz to10Mhz to a output of 2Vpp differential signal using the THS4551 and then connect it to an in put of ADS5294 ADC.
Is it possible to achieve a full-scale range in the ADC by configuring it?
If possible, could you please confirm how it should be configured to achieve this?
which value should i set in gain resistor and in feedback resistor in this application ?
My Vocm is 950mV.
I'm Confused to set my VCC and VEE according to my requirement.
Below given simulation circuit can i get output as per my requirement if yes then which values should i set as per my requirement.
