With our INA228, we’ve been using shunt resistors with 4 pins designed for kelvin sensing like RES SMD 1 OHM 1/2W 2516 WIDE.
Example Y08501R00000F9W - $12.82 each
What is the consequence of using a wide body, 2-pin resistor like RES SMD 1 OHM 1/2W 1206 WIDE?
Example RCA06121R00FKEALS - $0.32 each
We could still have 4 separate pads where 2 can carry current and 2 measure voltage drop…
Or if not necessary, we could use 2 pads with low impedance traces for current and high impedance traces for voltage drop measurement.
There appears to be more availability and lower cost for the 2-pad resistors. Thanks.
