Part Number: LM2904
output voltage is bigger or smaller than Theoretical.
Hi Sam,
Could you clarify what the expected and measured input and output voltages were? Also, what is VCC value?
Ashley
Hi Sam,
Are there any updates to this thread or further questions?
In the meantime, I will mark this thread as "TI Thinks Resolved" but please let us know if there is additional information or questions.
Thank you!
Ashley
Hi Ashley,
Please refer below wave picture, there is one random channel failure in one chip.
Hi Sam,
Could you clarify what these waveforms correspond to on the op amp pins? Are these the output waveforms?
If the waveforms are the outputs what are the inputs?
Ashley
INPUT1&2,PIN3 and PIN5 wave are same,PIN2 and PIN6 connected to GND.
abnormal ouput channel is randonm, failure pcs always has one channel out put as above,PIN1 OR PIN7
good output as above, the gap between good and ng is about 100mv.
the magnification is about 21.
Hi Sam,
Has the customer tested this outside of their system? Also, what is the intended input signal?
Ashley
