Part Number: TLV1842
Other Parts Discussed in Thread: TLV3603
hi sir
I need to hold the output signal after comparator output & adjust hold time
did you have any advise,thanks
Hi Alex,
What other specifications do you require for the comparator (propagation delay, voltage range, output type, etc.) and what is the application for this comparator?
We have TLV3603 which is a high-speed single channel comparator with an adjustable hysteresis/latch pin. Driving the latch pin to VEE causes the comparator output to be latched to its last active state. Here is the datasheet: TLV360x 325 MHz High-Speed Comparators with 2.5 ns Propagation Delay datasheet (Rev. E)
