Part Number: LMH6611
Other Parts Discussed in Thread: THS3491, OPA2675, OPA891
Hi team,
Do we have higher current amplifier but with similar spec with LMH6611? LMH6611's 100mA drive current is not enough.
Hello Naizeng,
I can certainly recommend a higher output current drive amplifier from our portfolio. What additional specifications of the LMH6611 are you most interested in?
For example:
- What are your bandwidth needs?
- What supply voltages will you be using?
- Would you condsider a current-feedback op-amp (higher bandwidths at high gains, higher slew rate, not as good offset voltage & bias current)?
- Do you have specific package-size, multi-channel, or cost needs?
- Are noise, distortion, and/or rail-to-rail input/outputs important to your application?
To start I would recommend our OPA891/892 family of devices, which have single & dual channel op-amp packages. I would also recommend looking at THS3491 and OPA2675 if current-feedback amplifiers would work in your application.
Alec
