Good afternoon! I'm working with an account that manufactured chambers to simulate different environmental changes. Their chamber sensing unit likely uses several repeats of the same/similar precision op-amp in a sensing analog front end, but I'm not currently sure which product to recommend.
My only real knowledge about the customer’s system is that they expect high sensitivity sensing from up to 4 sensors at a time (in each AFE). The signal from the AFE will likely go through signal isolation prior to feeding into the MPU/FPGA.
Can you provide any baseline product recommendations I could use to propose starting products before intersecting directly with their engineers and learning more about their system? Feel free to make any assumptions about the EE or system in order to make this recommendation (power consumption, size both not very important, etc)!
