LMH6554: power supply selection for the amplifier
Part Number: LMH6554
I have a question regarding the power supply requirement for the LMH6554 full difference amplifier.
I want to use this amplifier as a current sensor amplifier along with a shunt resistor. The current is expected to go negative.
In this case, do I need to provide a negative power supply for the amplifier to have a negative voltage output?
Or is it possible to operate with a single supply and set the common voltage through Vcm pin?
Thank you,
Steven
  • Hello Steve,
    I would recommend using a split supply configuration if you need negative input signals.  The input common-mode range of the amplifier requires headroom from the rails, at +/-2.5V the input common-mode range is +/-1.3V.
    You can try to shift common mode around the amplifier, but this can result in issues if the amplifier sees a common-mode input signal below its lowest supply.
    Alec
