Part Number: LM358
Hi Team,
I have come across a circuit as attached below. Could you please explain the circuit?, why this LM358 is used here
Part Number: LM358
Hi Team,
Arjun,
The inputs need to be swapped for this ground reference supply output to work at all.
The LM358 output is likely to oscillate because output capacitance, Adding a capacitor from output to IN- can help stability. R378 doesn't allow much output current, so output ground current in limited. LM358 doesn't switch between active souring and sinking quickly, so it's not the best choice.
For everything about LM358 see, [APP] Design Guidelines for Devices with LM324/LM358 Cores
