Hi TIer
There are two parameters that have not been found in datasheet. Could you give me some suggestion?
1, open-loop gain with temperature change
2, common mode voltage input range
Thank you very much.
Hi TIer
Hello Yuxi,
OPA2810 has specifications listed at 10V and 24V power supply differential. Both input common-mode voltage and open-loop gain can be found in the parametric tables, and both supply voltages have the same values (pages 6 and 9) which means these specifications are not affected by supply voltage configuration within the recommended operating conditions:
Thank you,
Sima
