Part Number: OPA2387
For OPA2387, how much does input bias current vary between two op-amps in a single package?
Hi Bruce,
This is hard to estimate. The datasheet indicates that the max difference at Ios at input should not exceed ±400pA per op amp over temperature. If you double the difference, that may be the worst case over temperature.
±Ib input bias currents suggests that the op-amp have the self-compensation circuit at the input. Typical Ib mismatching at input is approx. ±30pA at room temperature ( ±150pA is the worst case per op amp at 25C).
If you have other questions, please let us know.
Raymond
