hello.
I would like to inquire about the INA296A2QDDFRQ1 pcb pattern.
From shunt resistance
Each pattern is connected to pins 1 and 8 of INA296A2QDDFRQ1.
In this case, does the pattern have to be the same length?
To match the pattern length, I set the pattern as follows.
If the pattern length must be the same. Please check if you can do the following.
Especially the blue circle part.
I turned around like the blue circle to match the pattern length on both sides
