Subject: Clarification Needed on PDbar Pin Behavior at ±2.5V Supply
Hi everyone,
I am working with [OPA858-Q1] and have a question regarding the PDbar (Power Down) pin.
The datasheet mentions that for normal operation, the PDbar pin must be connected to the positive supply. However, under the "Power Down" section, the behavior at ±2.5V supply seems to differ.
- What should the PDbar pin be connected to when operating at ±2.5V to enable the op-amp?
- Could someone explain the reasoning behind this behavior?
- will there be any change in voltage at input inverting terminal if we are giving PDbar to positive supply?
I appreciate any insights or references to clarify this.
Thank you!
