Part Number: INA238
Other Parts Discussed in Thread: INA4230, INA4235
Dear technical support,
we are building an Automatic Test Equipment to power up 16 DUT while measuring the supply current through an array of 16 INA238.
I'd like to use the ALERT pin mainly as an overcurrent detector, so that its signal should be fed back to the high-side switch controlling the DUT, in order to cut the supply from that specific DUT.
My question is: since the ALERT pin also has the "Conversion Complete" functionality, can I simply feed the ALERT signal to a logic that controls the high-side switch (e.g. and AND port: ALERT + the mcu signal)?
Is there a better way to manage 16 ALERT signals from 16 INA238? Note that only one DUT at a time is powered up.
Eventually, can I connect all the 16 ALERT signals to a single bus, and utilize a microcontroller deactivate an high-side switch during an overcurrent event?
Thanks for your support,
Andrea
