Part Number: PGA281
Other Parts Discussed in Thread: PGA849
Hi expert,
My customer is evaluating PGA281 and want to know if the VOCM and VO-N can connect to 0V (GND)?
Ryker
Hello Ryker,
Yes the VOCM and VO-N can be connected to 0V (GND) as long as the datasheet is not violated.
Here are the conditions for VOCM:
For ideal output conditions I recommend to make VOCM mid supply between VSOP & VSON.
Since VO-N will be connected to ground, the differential output will be turn single-ended.
Here is an example from the datasheet:
What power supplies and expected input voltage/frequencies does the customer have? If single-ended output is needed, the newly released PGA849 might be a better fit (depending on gain needs).
All the best,
Carolina
