Part Number: LM358
We have developed a metering application which use dc offset voltage to measure the ac voltage and current.
We have used LM358 to generate 1.65VDC Offset voltage and that voltage is provided to neutral terminal of 3phase voltage and current circuit. It is working as expected but it generates noise on output side and isolation issue when neutral is connected with main supply.
I intend to validate that does this scheme will work.
Kindly validate the attached schematic and let us know if any modifications is needed on sensing section.
