Part Number: TLV9062
Other Parts Discussed in Thread: INA381
Hi team,
The customer has such a requirement: the input current is 1.5uA~400uA, need to transfer current signal to voltage signal, then noninverting amplifier the signal, finally compare the signal with 0.3V to get a high level signal. When the input current is 1.5uA, need to get a high level output, The total response time need to limited in 50us. Could you help use op-amp to realize the above requirement, including signal transformation, signal amplifier and compare. By the way, the system input voltage is 3.3V. So if have any recommendation, please help provide the PN and if possible, please also share the system design with us.
