Part Number: OPA2210
We are using 'OPA2210IDGKR' opamp in one of our designs. We are using this opamp as anti alias filter before ADC. I have attached the image of anti-alias filter and its TINA simulation file. The filter is designed for cut off frequency around 38KHz. The sensor output is provided to the anti alias filter with some MUX IC such as (TMUX1204DQAR) and opamp (OPA192IDBVR) are present in the path. The signal flow is as below,
Sensor ---> 'ADG5419BCPZ-RL7' MUX ---> 'OPA192IDBVR' as non inverting buffer ---> 'TMUX1204DQAR' MUX ---> 'OPA2210IDGKR' as 2nd order LPF anti alias filter.
So, we want to calculate total delay for signal from sensor output to anti alias filter output. Can you please provide the required calculations to find out the time delay and phase shift if any caused due to anti alias filter designed using 'OPA2210IDGKR' IC.
Note: sensor signal amplitude will not be greater than 5V it will be 0-5V.
Nitesh
