Other Parts Discussed in Thread: INA199, INA186
Hello
First of all, thank you for reading this post.
I'm working on designing a circuit for a 10 Gigaohm megohmmeter. The high-voltage circuit works fine with 1000 volts output. I searched online and found the INA190. I decided to use it to test current sensing because it has a low input bias current (0.5 nanoamps). The circuit I have is as follows:
However, I'm experiencing a fairly high noise level on the output, which prevents me from measuring values above 500 megohms. I'd like to know if anyone knows how to correct this situation by attenuating the noise and improving the circuit's response. This is the signal capture with a reference value of 1300 megohms.
I'd also like to know if there are better options for this purpose.
Thank you for your time.
