Part Number: THS4131
Dear sir,
10 no of THS4131 ic used in our design.
its discipate more heat.
Could you please tell solution for controlling heat discipation i.e's more than 60 degree.
Dear sir,
Could you share an idea of your design? Are these THS4131 ICs used for separate channels, or in a series of active filters?
What package are you using of the THS4131? Can you provide the your input signal, desired output signal, and what your load is on the FDA output?
I am glad to properly assist you once I know more about the system. Controlling power dissipation on the IC can be accomplished in multiple ways, including by tuning the design, properly matching the load, and consideration of PCB layer design.
Alec
1.Idea is for bandpass filter with differential input.
2.Fc=200KHz,BW=60KHz.
Please find the below link for our circuit reference.
Thank you for the filter details. I will provide a response to you once I review what you have sent to me.
Alec
