Part Number: OPA2171
hi team,
customer want to know the tolerance of 0.65mm pitch and1.27mm pitch as below.
do we have some info to confirm the pitch range here? tks for the checking.
Hi Allen,
This question would be easily answered by our packaging team. For this reason I am looking for a contact for you internally that could answer packaging related questions.
Chris Featherstone
Hi Allen,
Carrie is OoO. Sorry for the delay.
it is weird that the 3.1-2.9 not = 0.13, and C 0.1 > 0.13, can you explain more? tks here
The following marking indicates the mechanical datum control for the pin tolerance. Anyway, I have to look it up, and the pins' tolerances are specified in the drawing (I have to use GD&T terminology).
If you have additional question, please show the drawing to a mechanical engineer who will tell you what these markings mean.
If you have other questions, please let me know.
Raymond
hi Raymond,
tks for this new explanation, but the customer who is CQE only, is not a mechanical engineer ,so them still not clear to know how to reflect to the mm tolerance.
is there a clear calculator language to reflect the tolerance of 0.65mm here? i think a formula to show how to calculate it will be perfect.
Hi Allen,
We will confirm the calculation with our mechanical engineer and let you know for certain. From the drawing, thelead frame spacing estimation is the following.
Raymond
Hi Allen,
Please see below for the packaging engineer's response regarding lead pitch tolerance.
The tolerance for the leads of SOIC and VSSOP will differ due to their size, lead pitch, and overall design differences.
In general, the lead tolerance for VSSOP is more stringent than SOIC because VSSOP is a smaller, more densely packed package with a tighter lead pitch.
Please refer to the chart below.
SOIC |
VSSOP |
Lead pitch |
1.27mm |
0.65mm |
0.5mm |
Lead width (depends on the lead pitch) |
About 0.35mm - 0.51mm |
About 0.17mm - 0.27mm |
Lead width tolerance |
0.25mm |
0.13mm |
0.08mm |
Origin of the document |
JEDEC MO-059 |
JEDEC MO-187 |
The above are general ranges and typical values. The specific SOIC or VSSOP components produced by different semiconductor manufacturers may have slightly different lead sizes and tolerances. JEDEC MO-059 and MO-187 are public documents, and are available for download from the JEDEC website.
Carrie
